588,507 active members*
4,598 visitors online*
IndustryArena Forum > CAM Software > FeatureCAM CAD/CAM > How to make FeatureCAM2.5D mill 3D profiles...
    Mar 2007
    29
    I want to make a few AR-15 lower receivers for personal use out of 6061 T6 billet. I've got the .igs file and can import it into FeatureCAM fine, set the stock dimensions fine, etc., but when I try to use feature recognition, it tells me that it won't be able to machine the part because my company didn't opt for the mill3D option....we only have turn, turn/mill and mill2.5D. There's GOT to be a way that I can machine this part, but I'm so new to CAM software that I just can't see the light at the end of the tunnel. Can anyone here lend me a hand?
    I can also send the .igs file to anyone with enough time to help me. This will be machined on an older Toyoda FH45 horizontal with a FANUC11 controller and a 5K RPM spindle. When the FeatureCAM guys were there working on my post, they machined one of their demos to make sure that everything works....their "bottle mold." It looks like I could use whatever programming they used for this part, but I can't seem to figure it out.
    For what it's worth, here was my plan:
    drill all holes first
    6" flycutter to face to a depth of .010 away from the finished face:
    .750 3FL carbide e.m. to rough the outline and profile
    .500 4FL carbide ball e.m. to rough the contour/profile of the face
    .250 4FL carbide ball e.m. with a .004 stepover to finish profile the face
    Any help/ideas/suggestions?
    Thanks in advance,
    -WRM
    Sep 2003
    363
    Use the .igs file to make a solid or curves, then features and post your code. I don't have the time to step by step this. That is the way those of us who did'nt have FR did it every day. Go to the help file and check out curves from 3D file or something like that.
    Gary
    Mar 2007
    29
    Quote Originally Posted by duluthboat View Post
    Gary
    Thanks Gary, I think I've found what you're talking about.
    -WRM
    Mar 2008
    15
    I would like to get a copy of the .iges file if you dont mind. Featurecam likes .stl files alittle better if your using feature rec. [email protected]
    Mar 2006
    42
    if you would like to send me the iges i can see what i can do to help
    there are several options that can be taken instead of AFR or even recognition
    i can give you all the curves or even the geometry
    or i can send you an FM of the part with the features created and you can post to your processor
    Rick
    [email protected]
  1. Grinding Cam profiles on a DeskCNC 4 axis mill
    By Paraprop in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-15-2015, 06:16 AM
  2. What can I make with my router/mill
    By ToyMaker in forum DIY CNC Router Table Machines
    Last Post: 11-17-2014, 10:36 PM
  3. Best tooling for 1/2" profiles on a micro mill?
    By sansbury in forum Benchtop Machines
    Last Post: 02-25-2008, 06:07 AM
  4. Want to make a cnc mill for under 2000.00
    By sgman in forum Benchtop Machines
    Last Post: 02-20-2008, 02:24 AM
  5. what do you make with your mill?
    By heilcnc in forum Benchtop Machines
    Last Post: 10-08-2006, 09:00 PM
