588,202 active members*
4,542 visitors online*
    Jul 2015
    Question Rough Cutting
    Hi All,
    I am new here and this is my very first time using a CNC machine. I am having some issues with the roughness of the cut.
    I am trying to cut letters from a 12mm board using a 4mm drill, travelling 20mm/sec doing to passes of 6mm and the spin rate is full.
    Can anyone tell me where I am going wrong? I have attached a photo of the cut.
    Thanks in advance
    Zeak
    PS. Not in Australia but close by in Vanuatu
    Jun 2013
    1041
    Re: Rough Cutting
    Are you really using a drill bit? If so you shouldn't be. If your using a router bit I'm guessing it's a up spiral. Instead try a down spiral or compression spiral bit. It will get rid of the frayed and chipped top edge.
    Ben
    Jul 2015
    Re: Rough Cutting
    Hi Ben, thanks for the advice, yes your correct I am not using a drill bit, it is a spiral up bit. I will try and get my hand on a down or compression bit see how that looks.
    is there any good place to order on-line in OZ?
    Zeak
  1. how to calculate the cutting force for a rough end milling operation
    By praveenkusuma in forum Mechanical Calculations/Engineering Design
    Last Post: 07-10-2010, 05:25 AM
  2. Stumped - Cutting a square with a rough and finishing cut
    By loedward22 in forum Uncategorised MetalWorking Machines
    Last Post: 09-15-2009, 12:33 PM
  3. Initial Feeler - Rough Pricing for Cutting and Rolling
    By ukchris in forum Employment Opportunity
    Last Post: 01-10-2007, 09:29 PM
  4. Need help with rough cutting(backlash??)
    By bd007 in forum Commercial CNC Wood Routers
    Last Post: 03-08-2006, 10:49 PM
