588,197 active members*
4,476 visitors online*
    Jul 2003
    162
    1018 or 4140?
    I'm wondering in the McMaster Carr "precision acme rod" in black oxide coated 4140 steel gives any advantages over 1018? I know 4140 is harder but is the finish any smoother? (more power for cutting and less for turning the AB nut). Is 4140 less inclined to whip or anything?
    Inquiring minds want to know Thanks!
    Aug 2007
    147
    4140 has higher tensile strength, but offers no advantages in terms of rigidity. Both metals have the same modulus of elasticity.
    I don't know if Mcmaster's 4140 acmes are smoother.
    Feb 2007
    1084
    4140 will have better wear charictaristics as it is in the Chome-Moly family of steels, 41xx. Also has better tensile streangh and is hardenable, all advantages over 10xx steels, for your application.
    MC
    Sep 2006
    6463
    Yeah, 4140 is as hard as a whores heart to machine, but for hi tensile applications it's the bees knees.
    You'll still be running it against bronze nuts, so no advantage wear wise.
    To get a good finish it needs to be ground.
    Ian.
    Aug 2007
    339
    There is a good reason why 4140 makes a good gun metal. It's tuff stuff.....
  1. CRS 1018 Tooling Help
    By fhadk in forum MetalWork Discussion
    Last Post: 11-06-2008, 09:03 PM
  2. 1018 Round Stock in SE PA
    By buckkillr8 in forum Employment Opportunity
    Last Post: 08-06-2007, 08:55 PM
  3. Drilling question 1018 and 4140
    By schiada96 in forum Uncategorised MetalWorking Machines
    Last Post: 11-27-2006, 05:45 PM
  4. Turning 1018
    By mjarus in forum Mini Lathe
    Last Post: 06-23-2006, 03:46 AM
  5. ACME - 1018 steel or heat treat 4140 alloy
    By CnC_BoY in forum Linear and Rotary Motion
    Last Post: 03-21-2006, 11:41 PM
