587,303 active members*
3,903 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > PCNC1100 Series III - 770 Base Casting??
Results 1 to 9 of 9
    Nov 2005
    157
    After finally getting my new PCNC1100 home & in the workshop over the weekend, I noticed a bit of an anomaly and I wonder if anyone else can confirm this please?
    The base casting looks totally different where the mounting/stand bolting points are, and looks identical in shape (don't know about size..) to the 770 base casting, and needs to be bolted down with 40-50mm long M12 bolts, rather than the M12 x 130mm studs supplied. The shape and size of the casting are physically quite different to all the literature.
    Are all 1100 Series III bases like this????
    Jan 2012
    51
    Confirmed - I had to bolt the mill to the base using the M12 bolts. Yes, different from the literature.
    Not sure about the similarity to the 770.
    Regards,
    Geo
    Mar 2009
    1863
    (chair)What difference does it make what size the bolts are? Do they fit or not? If they fit, use them. If they don't fit, contact Tormach. How much simpler could it be.:bs:
    You can buy GOOD PARTS or you can buy CHEAP PARTS, but you can't buy GOOD CHEAP PARTS.
    Nov 2005
    157
    Quote Originally Posted by Steve Seebold View Post
    What a silly response Steve, I'll assume you missed the main query point about the Base casting ( I only mentioned it 3 times....)?
    Of course the bolt length doesn't make any difference - it was the mass, shape, & size of the casting I queried.
    Gjvander - many thanks for confirming that.
    For anyone who didn't get what I meant here is a picture of the *new* base casting/foot detail.
    Peter
    Jun 2012
    59
    Looks very similar to my 770.
    Oct 2011
    477
    Very different from my Series II 1100.
    Feb 2006
    1072
    Your PCNC770 stand looks quite different than the earlier ones I've seen, Peter.
    See http://groklab.org/tormach/files/2011/03/IMG_0014.jpg for an example.
    I have a Series 1 PCNC1100 and have been Jonesing on the tall riser blocks on the (apparantly earlier) 770 stands. It's hard for me to fully flush/sweep swarf out from under my 1100 with its short risers (more like the height of yours).
    Maybe this also acccounts for the difference in stud/bolt length?
    Randy
    673
    I have a new series III... looks just like that....
    Feb 2006
    1072
    Oops, I should have read your original post a little closer, Peter. Anyway, another pic of the "tall riser" 770 stand is at http://img256.imageshack.us/img256/1462/standhm.jpg I wish the 1100 stand was more like this.
    Randy
  1. My first thoughts on my PCNC1100
    By turbostang in forum Tormach Personal CNC Mill
    Last Post: 07-05-2012, 02:39 PM
  2. FANUC P25 Base 2 Board for Series 15
    By gbowne1 in forum Fanuc
    Last Post: 01-23-2010, 05:32 AM
  3. Replies: 22
    Last Post: 10-08-2009, 03:57 AM
  4. Lead time on PCNC1100 Series II
    By _swede in forum Tormach Personal CNC Mill
    Last Post: 10-28-2008, 04:15 PM
  5. Just how strong are the holes in a Series I base?
    By AviatorDave in forum Bridgeport / Hardinge Mills
    Last Post: 02-10-2008, 12:48 AM
