587,243 active members*
3,183 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Peck Tapping in BobCAD ?
    Oct 2009
    254
    Hey guys,
    Running Bobcad V28. The does a lot hole tapping on the Haas VF3-YT50. Material is 304SS. Is it possible to Peck Tap in Bobcad? I don't see an option for it like there is for drilling. I know the Haas is capable of it by turning on setting 133. This makes the spindle orient each time it enters the hole.
    Here is a snip of the code: (It's just doing a single depth) Would prefer multiple pecks to clear the hole out of chips.
    (TOOL #10 Badger UNC 5/8-11 Hand Tap)
    N917 T10 M06
    N919 T13
    N921 G90 G54 X1.5 Y2.1275 S98 M03
    N923 G43 H10 D10 Z1. M08
    N925 G00 Z-0.2
    N927 G95
    N929 G84 G99 X1.5 Y2.1275 Z-1.3506 R-0.3 F0.0909
    N931 G80
    N933 G94
    N935 G00 Z-0.2
    N937 Z1.
    In the Haas example on Youtube, they are showing multiple tap pecks.
    X0 Z-1. ;
    X0 Z-1.5 ;
    X0 Z-2. ;
    X0 Z-2.5 ;
    Any ideas?
    Thank you.
    Oct 2009
    254
    Re: Peck Tapping in BobCAD ?
    If BobCAD doesn't support peck tapping for some reason, looks like I will have to Post the code and make the entries manually. Here is a better description of what peck tapping looks like. Taken from the Haas video.
    Mar 2012
    1570
    Peck tapping is not an in the box feature for the software, you could write a script to post code like the example above. Using the ADV posting tab the software api and a custom script you can format the code to do just about anything...
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    Aug 2012
    9
    We don't do much tapping, but below is another verified way to program with peck. The program is for a 304SS manifold. Bobcad may not have an option for peck tapping, but this is easy simple copy and paste. Running a Haas VF-3SSYT with Next Gen control here. Here's the peck portion of the program:
    (****** TOOL CHANGE *** T05 ***)
    (1/8-27 PIPE TAP NPT)
    N355 M06 T05
    N360 T01
    N365 G54
    N370 G90 G00 X-1.125 Y0. S150 M03
    N375 G43 Z.2 H05 M08
    N380 G98 G84 X-1.125 Y0. Z-.1962 R.2 F5.55
    N385 G84 Z-.3923
    N390 G84 Z-.6485
    N395 G84 X-1.625 Z-.1962
    N400 G84 Z-.3923
    N405 G84 Z-.6485
    N410 G84 X-2.125 Z-.1962
    N415 G84 Z-.3923
    N420 G84 Z-.6485
    N425 G84 X-2.625 Z-.1962
    N430 G84 Z-.3923
    N435 G84 Z-.6485
    N440 G84 X-3.125 Z-.1962
    N445 G84 Z-.3923
    N450 G84 Z-.6485
    N455 G84 X-3.625 Z-.1962
    N460 G84 Z-.3923
    N465 G84 Z-.6485
    N470 G84 X-4.125 Z-.1962
    N475 G84 Z-.3923
    N480 G84 Z-.6485
    N485 G84 X-4.625 Z-.1962
    N490 G84 Z-.3923
    N495 G84 Z-.6485
    N500 G84 X-5.125 Z-.1962
    N505 G84 Z-.3923
    N510 G84 Z-.6485
    N515 G84 X-5.625 Z-.1962
    N520 G84 Z-.3923
    N525 G84 Z-.6485
    N530 G84 X-6.125 Z-.1962
    N535 G84 Z-.3923
    N540 G84 Z-.6485
    N545 G84 X-6.625 Z-.1962
    N550 G84 Z-.3923
    N555 G84 Z-.6485
    N560 G80 M09
    (EOMP-RETURN TO PART CHANGE POS)
    N565 M98 P9002
    N570 M30
  1. Peck tapping
    By voytek1 in forum Fadal
    Last Post: 12-08-2016, 02:55 AM
  2. Peck Tapping
    By crandalljclj in forum MetalWork Discussion
    Last Post: 04-16-2012, 12:22 AM
  3. 17-4 peck tapping
    By Delw in forum Haas Mills
    Last Post: 12-11-2010, 02:43 AM
  4. peck tapping
    By bolton78 in forum MetalWork Discussion
    Last Post: 02-02-2010, 10:44 PM
  5. Peck tapping
    By Mitsui Seiki in forum MetalWork Discussion
    Last Post: 11-28-2007, 04:30 AM
