588,232 active members*
4,727 visitors online*
    Oct 2004
    198
    Jerky Stepper Motor Fix
    Hi, I've setup a few different machines (routers/grinders) using Mach3 with steppers and Gecko G540 drives, servos with CNC TekniX Drives with great success.
    But recently I setup a grinding machine with C32 Breakout Board, 1200oz/in steppers and G201x drivers set to 6amps and a 48v power supply.
    For the most part it seems to work but when jogging the motors jerk every so often, it's very similar to a servo motor having a very large positional error set, then losing position and catching up.
    Any ideas why it might have this type of behaviour.
    BTW does it matter if we use a switching power supply rather than a linear power supply?
    Here's the BB: CNC4PC
    Here's the motor: 1200 Oz-in Nema 34 Stepper Motor - $121.00 : AusXmods
    Darc
    Oct 2005
    2392
    Could it be from a PC delay? If the PC is running Windows it will delay the outgoing step pulses when Windows is busy, like internal interrupts etc. It's generally advised if you have to use Windows to shut down everything not essential.
    Oct 2004
    198
    Hi RomanLini, I set everything as per the Mach3 optimisation guide but no difference.
    I noticed though if I set velocity to 4000 and acceleration to 120 its quite smooth, but any higher or lower it's pretty average (groans abit and is jerky).
    The main thing that stood out was if I move one axes it sounds/looks great but if I move two axes they are quite noisy and seem a bit jerky.
    It's strange because they are both on seperate power supplys.
    So very confused????????????
  1. Power Supply for 4 Stepper Driver 32-65VDC and 4 Stepper Motor 65V 2.3A
    By guy2b1 in forum DIY CNC Router Table Machines
    Last Post: 03-08-2011, 12:50 PM
  2. jerky stepper motion , no missed stepps
    By doc0302 in forum Mach Mill
    Last Post: 12-19-2010, 07:43 PM
  3. 6 leads stepper motor connect to TB6560AHQ stepper driver board
    By wf1318 in forum Stepper Motors / Drives
    Last Post: 07-25-2010, 08:19 AM
  4. Integrated stepper motor? with built-in stepper motor driver
    By uirobot in forum News Announcements
    Last Post: 06-07-2010, 09:59 AM
  5. Beltdrive-stepper motor-stepper motor driver
    By Georg in forum Stepper Motors / Drives
    Last Post: 10-16-2007, 10:56 PM
