588,676 active members*
6,715 visitors online*
Results 1 to 1 of 1
    Nov 2009
    115
    Import a laser cutter from china
    Gweike laser cutter is biggest laser cutter manufacture in north of china.we make one new model LC1313,which can cut wood,acrylic,rubber etc,also the stainless steel,carbon steel,spec is as follows:
    Model LC1313
    Engraving size 1300*1300mm
    Overall dimensions 2,100x2,000X1,200mm
    Laser power V6(130w)
    Cutting speed 0 – 50 mm/s
    Reposition accuracy ±0.05mm
    Working voltage AC110- 220V±10%,50-60Hz
    Consuming power less than 1,000W
    Working temperature 0 - 45°C
    Working humidity 8 - 95%
    Minimum letter size English :1 x 1mm Chinese:2 x 2mm
    Supported file format BMP, HPGL, PLT, DST, DXP, and AI
    Driving system Servo motors
    Laser tube cooling type Water-cooling chiller LW16 or cooling machine and protection system
    Other auxiliary equipment Exhaust-fans and air-exhaust pipe
    Laser control software DSP control system
    Compatible software CorelDraw AutoCAD Photoshop
    Laser tube type: Sealed CO2 glass laser tube
    also pls check the detailed picture of the machine in attachment
    Attached Thumbnails Attached Thumbnails laser head.jpg   control case.jpg   111_.jpg
  1. Laser cutter from China
    By techasist in forum Want To Buy...Need help!
    Last Post: 02-28-2013, 11:50 AM
  2. Import Ipl and Yag Laser machines from China
    By sam1 in forum Community Club House
    Last Post: 11-01-2010, 10:38 AM
  3. (SyiL China)will participate in the 107 session of China Import and Export Fair
    By syil in forum Trade Shows / Webinars / Other Events
    Last Post: 02-26-2010, 01:28 AM
  4. China Laser engraver & cutter
    By canozkan in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-15-2009, 05:03 AM
  5. China laser cutter
    By signbloke in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-15-2006, 04:31 AM
