588,272 active members*
8,978 visitors online*
IndustryArena Forum > MetalWorking Machines > Syil Products > Z-Axis Trouble on Syil X4 (using Mach 3 CNC Controller Software)
    Feb 2009
    Hello,
    I have a Syil X4 CNC Mill, and I use Mach 3 CNC Controller Software by Art Soft Software. My mill has worked great for months, but I went to use it the other day and the z-axis got reversed. When I tell the mill to move up, it goes down, and down when I tell it to go up. The x and y axis work fine. Has anyone experienced this before?
    Jon
    Mar 2005
    59
    Quote Originally Posted by jharris View Post
    Hello,
    Jon
    Check, Config>Ports and Pins>Motor Outputs>Z-axis - Change DirLowActiw
    ... to Red or Green and restart Mach.
    Hope that helps!
    Jan 2009
    13
    you also can change the setting of mach3 as follow:
    config -> homing/limiting -> reversed,find z,change it,than Z axis will work ok
  1. Syil X3 Erratic Spindle Speed with Mach
    By reithguitars in forum Syil Products
    Last Post: 01-21-2017, 08:43 AM
  2. Syil c6 cnc controller box needed!!
    By gglynn81 in forum Syil Products
    Last Post: 09-19-2008, 12:29 AM
  3. Syil Controller - probe input?
    By john_t_h in forum Syil Products
    Last Post: 03-02-2008, 04:05 AM
  4. Jerky Movement - Syil X3 Mach 3
    By Megaplow in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-09-2008, 04:10 PM
  5. Syil Controller Question
    By mayhugh1 in forum Syil Products
    Last Post: 02-06-2007, 08:39 PM
