587,999 active members*
1,980 visitors online*
Thread: HAAS VF3
Results 1 to 6 of 6
    Jan 2004
    63
    HAAS VF3
    It has been awhile, but I am climbing back into the seat. I am working out some serial connection issues with the machine, but I did drop in code to the machine via floppy disk before.
    I am starting with some simple engraving. When I generate the code, each line has N #'s , and code I generated years ago does not. I have selected the HAAS VF series for the NC config. Should I select something else?
    Also, aother dummy newbie question. How do I set the z depth globally in the code.
    Try not. Do. Or do not. There is no try.
    Jan 2004
    63
    I am using BobCad version 20
    Jan 2004
    63
    I tried to get some code into the machine last night. FAIL. Since I am working with ancient technology........floppy disks......... I had to go home to open the floppy and see what I did wrong. The code had 2-% signs in the begining and 2-% signs at the end. I think that may have been it. I will give it another wack tonight.
    Mar 2005
    368
    Quote Originally Posted by CamIam View Post
    .... The code had 2-% signs in the begining and 2-% signs at the end. I think that may have been it. I will give it another wack tonight.
    On the CAM side, go to File > Setup...
    There is where the second set of % signs are probably added.
    Either delete them or check the Strip First/Last Lines box.
    This affects code only when exported out of BC....so to verify, you need to open the g-code file.
    This works in v21, I think v20 is the same.
    Apr 2010
    260
    If you want to get rid of the sequencing e.g N100,N101,N102... you need to modify the post. Open the post in the text editor and hit CRTL F, and seach for sequence. On my HassVf it is line 207. Change the Y to N and save. when you post you will not have sequencing anymore
    www.machmachine.com
    Jan 2004
    63
    Well, I got it working!! Simple engraving to start with. I downloaded the art work from Cad Cam trainer.com.
    More to come.
    Attached Files Attached Files
  1. haas SL-20 to Haas bar 300 alignment plate needed
    By J-Mccoin 2009 in forum Haas Lathes
    Last Post: 12-03-2009, 04:13 AM
  2. RFQ haas SL-20 to Haas bar 300 alignment plate needed
    By J-Mccoin 2009 in forum Employment Opportunity
    Last Post: 10-28-2009, 08:17 PM
  3. Haas Super Mini-Mill and Haas Trunnion Table
    By Gabe Newell in forum Haas Mills
    Last Post: 06-07-2009, 07:23 PM
  4. Haas 2 haas serial comunication?
    By CNCgr in forum Haas Mills
    Last Post: 12-22-2006, 07:07 PM
