I have a drawing that is simply a 3 inch line.
when I machine this line into my material I would like it to cut some defined depth on each side of the line and then cut some other defined depth (deeper) directly over the line..
I know you see it the step down V cut...
I'm using RhinoCad 4 and RhinoCam 1..HTML Code:|_ _| |_|
Can I even get this tool path from a single line?
