587,216 active members*
2,708 visitors online*
    Aug 2012
    96
    Two servos for Y axis?
    Hi all, I'm documenting a build on my site, thunderdork.com.
    I bought a servo kit from Keling/Automation Technologies Inc. It came with the CNC4PC c11 breakout board and Gecko 320x drivers. I am at the point where I am wiring up the motors, controllers and breakout. I need to have two motors for the longer 8' y axis. Do I wire them to the same step/direction/com on the breakout and only use one encoder from the motors? Or do i use separate channels and set it up some sort of ganging in mach3/emc2?
    Thanks for any help you might have?
    If you're using Mach3, you set them up as two separate axis and slave them in the software.
  1. Need 3-axis CNC tabletop with servos
    By gemstoneartist in forum Want To Buy...Need help!
    Last Post: 04-11-2011, 07:28 AM
  2. BMC 25 - Z Axis creep when servos off.
    By gthlm in forum HURCO
    Last Post: 11-30-2010, 12:56 AM
  3. 5 axis servos
    By mtk in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-25-2008, 01:14 PM
  4. servos to control dual axis solar tracker
    By BullCreek in forum Servo Motors / Drives
    Last Post: 08-15-2006, 02:04 PM
  5. 2 servos/steppers on 1 axis?
    By m_c in forum CNC Machine Related Electronics
    Last Post: 07-18-2004, 03:44 AM
