Hello I have an issue with a computer that is setup with smooth stepper and has three ports 1,2,3. there are x,y,z,a axis enabled in mach and x,y,z all turn properly but "A" doesnt. I have checked for continuity on all 4 of the wires from db25 board to stepper drive for "A" and motor will run in 1 direction but not both, if I switch step and direction pins motor will spin in other direction? swithing high or low doesnt do a thing and Ive tryed or made sure that polarity is not an issue as well with step-+ direction-+ etc... used different port as well. Im at a lose? I think ill try a new drive, but not sure. Any idea will be thanked"!
