588,638 active members*
5,069 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > help geckog540 machs 3 spindle wiring
    Jul 2014
    4
    hi everyone.Have some probleme to control my cnc spindle whit my geckog540
    i use geckog 540 whit gecko540.xml
    spindle 4kw
    and inverter huanyang hy04d023b
    the spindle work great manual
    but i wiring inverto to my geckog540 and i try to control whit mach3 and noting have try some
    programming setup to my drive 002 at 1 or 0 nothing 0001 at 1 or 0 and nothing have take some picks of my wiring
    sorry for my english
    10v=9 to gecko
    vo=8 to gecko
    acm=7 to gecko
    Jan 2007
    467
    Re: help geckog540 machs 3 spindle wiring
    goorus,
    You can test the VFD output by connecting a 9V battery (or any straight DC voltage that is around 10V) between VFD IN and VFD GND and measure between VFD OUT and VFD GND with a voltmeter. You would then want to toggle the VFD signal in your software and see if you get a voltage change on your voltmeter. If you do, then the fault will lie with your VFD controller. If you do not, you will want to disconnect the DB25 from the G540 and measure the VFD pin on the cable to see if it is outputting any signal. If that is outputting the correct signal then the problem will lie with the G540; if it is not then it is a software setting that is not correct.
    I think I may have typed that a little too run-on-sentencey so if you need me to clarify just let me know.
    Marcus Freimanis
    www.geckodrive.com
  1. Spindle on wiring
    By rstbkt in forum CNC Machine Related Electronics
    Last Post: 10-30-2018, 03:43 AM
  2. Spindle wiring
    By justinj in forum Spindles / VFD
    Last Post: 12-28-2014, 03:54 AM
  3. Replies: 0
    Last Post: 11-24-2014, 01:24 AM
  4. Spindle Wiring Size
    By nuke33 in forum DIY CNC Router Table Machines
    Last Post: 08-27-2014, 02:09 AM
  5. help please with spindle wiring
    By anthow in forum DIY CNC Router Table Machines
    Last Post: 09-18-2013, 09:53 PM
