588,239 active members*
4,288 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Power up restart with large 5 axis parts Homing out A and B
    May 2007
    155
    any way to home the A and B separate when I power up and home out
    I have large parts that will crash when the A and B home out .. but some take
    days to machine
    I dont like to leave my machines on over night we get bad lighting storms here
    Jul 2005
    12177
    Use Zero Return Single axis.
    Do not push Auto Restart when you power up, just Reset then Zero Return, A or B then Singl Axis. Home all your axes individually this way.
    Nov 2003
    236
    You may also need to use the "Jog without Zero return" setting 53 to ensure you do not have a collision. But be careful that you do not over travel an axis - you could break something.
  1. Handling large parts
    By cdlenterprises in forum MetalWork Discussion
    Last Post: 06-15-2009, 05:13 AM
  2. Restart from power failure.
    By Farproducts in forum Excitech routers
    Last Post: 04-01-2009, 12:37 PM
  3. digizing large parts with MicroScribe
    By an-cadsolutions in forum Digitizing and Laser Digitizing
    Last Post: 03-01-2008, 11:24 PM
  4. Locating Large Non-Square Parts on a Five Axis CNC Router
    By Mexellent in forum MetalWork Discussion
    Last Post: 02-04-2008, 06:24 PM
  5. Large parts Molding techniques
    By MBG in forum Moldmaking
    Last Post: 12-09-2005, 08:44 PM
