588,227 active members*
4,423 visitors online*
IndustryArena Forum > CAM Software > Mastercam > mastercam and the m2
Results 1 to 13 of 13
    Jun 2006
    5
    how do i get mastercam9 mill1
    and a mazak m2 to converse
    Feb 2006
    103
    what do you mean ... to communicate with each other ... to load programs ... have it run properly ?
    Jun 2006
    5
    Yes I Cant Get The Two To Upload Or Down Load Any Thing
    Feb 2006
    103
    are you using a floppy disk or a DNC cable ?
    Jun 2006
    5
    dnc cable
    Feb 2006
    103
    obvislouly check your connections which im sure you already did .. but also make sure that your Baud rate match up with whatever program you use to send your programs and your machine. If you think that cable itself is bad try a new one, worse case you can always take it back.
    what programs do you use and what is your machine ?
    Feb 2006
    103
    you could also try a more detailed post in this fourm sub section
    http://www.cnczone.com/forums/forumdisplay.php?f=70
    Apr 2003
    3578
    Were did the cable come from did you make it the the wiring config for the Mazak?
    Cadcam
    Jun 2006
    5
    yes mastercam made the wire for us and we have had the machines drip fed by preditor but now our master cam post wont seem to work
    Apr 2003
    3578
    What is the post not doing that it did before.Not posting or not posting using the right post need more info as i am not see a communications issue post a post now issue.
    Did you just load this to a new computer?
    Cadcam
    Feb 2006
    103
    Thanks for jumping in here CadCam, I thought I could help since I just setup 3 machines with a DNC cable, but I was getting lost at the lack of infomation.
    Apr 2003
    3578
    I am with you the nore info the better.
    As I am a Mastercam & predator user but sounds like thats not the issue.
    Cadcam
    Feb 2006
    103
    yeah hard to say. But sounds more like a post issue and that is not something I trust myself enough to give info on. I dont like playing with my own but I will if need be.
