588,591 active members*
12,573 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Renishaw variable change? How to
    Oct 2010
    How exactly I can change Renishaw variables? I have HAAS with renishaw measuring probe. So i need to change for example this #562 back off distance, but how do I do it? Do i write it to MDI some how, or is it in parameters or somewhere?
    May 2004
    97
    Quote Originally Posted by cncJ View Post
    Look in Program 9724...
    Alter
    N600
    #[ #161 + 6 ]= 0.2
    Where:
    #161= 556 (START CALIBRATION VARIABLE)
    This value (0.2) is NOT an absolute distance but a factor - a smaller factor reduces the back-off distance.
    I would strongly suggest NOT changing the base variable from 556 as you may conflict with the tool setter variables!!!
    If you intend to fix the factor, it is probably best to recalibrate also just in case. (though metrology wise the back-off shouldn't affect performance)
    Jul 2005
    340
    I`ve changet #556 to 0.05 half year ago , and I am more happy than before , faster cycles and never had any collision.
    Current and commands -> few times PG DN ( until macro variables ) -> few times arrow DOWN ( until see the #556 ) and type your value.
    Peter
    Apr 2006
    133
    Don't use #500 series variables
    After reinstalling the renishaw software about 4 times we decided to change all our progams with #500 series variables to #600 series and have had no more problems. Thank goodness for "search & replace"
    I am amazed the the probing software doesn't protect the varianles they use.
    Love our probes!!
  1. How to change Tool change position(About MAZATROL T1 control)
    By liushuixingyun in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-07-2014, 01:33 AM
  2. Change variable by MDI
    By aidoru in forum Fanuc
    Last Post: 03-25-2010, 04:02 PM
  3. EMC2 variable pitch / variable diameter threading.
    By samco in forum MetalWork Discussion
    Last Post: 03-09-2008, 07:40 PM
  4. variable to change tool offsets in auto cycle
    By dalvinder in forum DNC Problems and Solutions
    Last Post: 09-04-2007, 09:45 PM
  5. Replies: 1
    Last Post: 06-30-2007, 03:30 AM
