588,644 active members*
4,755 visitors online*
    Aug 2006
    33
    Stainless Steel / Aluminum Cut and Rolled
    I'd like two pieces of stainless steel, aluminum or similar (something reasonable hard wearing and thin), each should be 735mm long and approx. 60mm wide, the edges should be rolled to match the profile in the attached diagram. To help cisualize the item it will be a sill plate to go in a car.
    I am also very interested in having a logo pattern cut in to the piece if this is possible. If these test pieces work out there may be more to come.
    Delivery would be to the Boston area, payment via cash, PayPal, check, money order by agreeable terms.
    Chris.
    kaderick Guest
    Did you get a quote?
    edit
    Aug 2006
    33
    No replies or PM's at all! *lol* I'll PM you with more details, what format would you need the logo in? I have it in Adobe Illustrator so it;s a vector image, I can export as PDF, EPS, DWG, JPG etc.
    Chris.
    kaderick Guest
    lol
    edit
