587,999 active members*
3,021 visitors online*
    Sep 2007
    fanuc spindle drive alarm no-10
    i have one okk cnc vertical milling,model no-PCV 40.
    this mc fanuc spindle drive alarm-10,sometime i off& on the drive alarm comes 16 also. pcb part no-A20B-1003-0010/14B,
    i checked input supply phase to phase 200V ok
    checked drive magnetic conductor,reacter,igbt,rectifier,capaciter all ok.
    alarm comes once i on control 2 to 3 minutes later.
    pls somebody advise me what is the problem?
    Jan 2007
    333
    (10) Alarm No. 10 .
    Input power voltage
    This aiarm indicates abnormally low AC power voltage (- 15% or less).
    drops.
    This alarm may be generated even during momentary power failures.
    Alarm No. 16
    1 External data memory (RAM) Replace memory
    defective
    2 PCB defective Replace PCB.
  1. Spindle Drive Alarm AL-03??
    By msmart in forum Fanuc
    Last Post: 02-02-2023, 05:21 PM
  2. Fanuc ac spindle drive alarm 01
    By suresh patil in forum DNC Problems and Solutions
    Last Post: 08-08-2007, 08:37 AM
  3. Replies: 2
    Last Post: 07-19-2007, 07:17 PM
  4. Alarm 123 Spindle Drive Fault
    By Shotout in forum Haas Mills
    Last Post: 05-27-2007, 05:48 PM
  5. Spindle drive alarm in fanuc 16 ta
    By miguisu in forum Fanuc
    Last Post: 02-20-2007, 05:12 PM
