Hi
I have a Mazak M5 lathe with a Fanuc 2000c Control. We have never been able to get it to run. A service guy from Mazak came out to look at it a couple of years ago. I don’t think he had a clue of what was wrong with this machine just told us to send off one of the velocity drives to get fixed. And see if that fixes the problem. OK the other day I was reading some post on if the batteries go dead you loss your parameters and you will get a parity alarm. So checked the batteries. The Battery on board #9 measured 4.8 volts, so I thought that one might be fine but the battery on board #10 was dead. replaced the battery turned the control on. I can’t get it to do anything. The parity light is on and it shows 16080206 or 12080206 on the display when you turn the control on and that’s all it will do you can’t turn anything on or off. I'm debating on finding a service manual because I don't know if it's worth fixing or not. Any ideas on where to start on this thing. Thanks
