Folks,
I sent a spindle out for a grind, chrome, regrind. When it came back from the grinding, the newly refinished taper looked great, but the clearance gap between the top of the toolholder and the spindle face seemed excessive. Since I don't have any dimensioned drawings for the spindle on this Miyano TSV-35, I can't know if it is correct. The grinder insists that it is, but I'm now having problems with occasional misses in the ATC, where it will close the retention collet too high on the pull stud and the tool won't be seated properly in the taper. Occasionally, it'll even be out of the drive dogs. What should the standard clearance be? Right now, it's about 80 thou.
As you can also see, the drive dog engagement isn't all that great either, which also bothers me. Can anyone tell me if this is normal and I should be focused on readjusting the Drawbar transition point, or should I be looking for another shop to do another regrind? Or both?
Thanks!
