587,663 active members*
3,474 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Eric's 3-axis machine from scrap and scavenged parts
Results 1 to 20 of 20
    Sep 2014
    30
    So much of this machine is built from scrap aluminum that was found by rummaging through the scrap bin at work. I purchased some of the larger items like the 3" x 1/2" side plates and the linear bearing extrusions. I got 2 steppers and 3 drives from work that could no longer be used on production equipment but was reported to have worked fine when the machines were disassembled.
    The build volume will be about 20" x 40" x 4"
    It uses some 8020 10 series along with some 1/2" aluminum plate. The y-axis side plates are 1/4" 7071 aluminum. I used 8020 gusseted angle extrusion for my linear rails. I may replace this by some proper linear bearing rails in the future but this is working nicely to get me going.
    Screws are 1/2-10 single start. The X-axis is geared to a 1:2 increase to make it act like a 2 start. All screws are installed under tension to minimize whipping.
    Steppers are Vexta 5 phase. The X and Y are nema 34 and the Z is a nema 23. I tested these out on a table top using the "roadrunner" g-code that comes with Mach3
    Here are a few pictures of the progress. It started out as a solidworks model:
    Here is my anti-backlash setup. There's a nice stiff spring between the 2 brass nuts. 1 nut is bolted to the extrusion that they are housed within.
    Look at the lovely kite that I machined.... Anyway, Here's what it looked like while I was using it as a manual router "mill" It came in quite handy in this configuration
    Here's the Y and Z axis assembly without the side plates
    This is the bearing assembly that I made. Based on the "buildyourcnc.com" book build but a bit better with that extrusion
    I picked up a variable speed dewalt for my "spindle" It will be powered from the control box so that Mach 3 can turn it on and off.
    An early version of my belt drive on the X-axis. The tension arms were replaced with something that worked a bit better
    Fitting up the X axis motor
    The control enclosure about a week ago. I have it about wired up now but need to clean up my wiring. The outlet on the side is turned on via a solid state relay that can be tripped from the breakout board. The power for that outlet runs through the normally closed side of the e-stop so that it will have a hard shut down as well when the e-stop is tripped. A breakout board input will be on the normally open side of the switch. there's a blue LED to indicate that the switch is not pressed. I'm running a network cable from the BOB through a cord grip that will run to the limit switches. A pendant that came with the BOB goes through a phone jack on the side of the box.
    Sep 2014
    30
    Re: Eric's 3-axis machine from scrap and scavenged parts
    The control enclosure is a bit more complete. I may do a bit of cable management and need to add some filtration. A little larger box would have allowed for some much nicer cable management here. BTW, wago wire nuts are awesome....
    I 3d printed a 2 piece bezel for my DB25 cable pass through that worked out quite nicely. I would have preferred to have the fan in the box, but I was running out of space in there.
    May 2005
    3920
    Nice!
    Like you I visit the scrap bin every day I'm at work. Unfortunately most of the scrap isn't exactly usable for machine builds but I'm getting there.
    Oct 2006
    84
    Can you upload the pics? They aren't showing up for me.
    Sep 2014
    30
    Here are a few. The other pictures are on photobucket
    Attached Thumbnails Attached Thumbnails 3axisrouter-solidworks-v4b_zps94c5d43c.jpg   S5030298_zpsbfd3971a.jpg   DSCN4237_zps3e18ffb6.jpg   DSCN2845_zpsbf59eeb2.jpg
    Jun 2012
    817
    Steppers look bigger than the spindle! That's gonna take one heck of a power supply.
    Sep 2014
    30
    The steppers and drives were free
    well, I had to buy one stepper, but they were ditching 2 motors and 3 drives at work and I snatched them up. I was told they work fine, just aren't supported anymore.
    And the drives for this one have the power supplies built in. They hook right up to 110AC power.
    Jun 2012
    817
    Quote Originally Posted by muttstang View Post
    Well that's handy. Free is a good price, especially since they are a matched system already.
    Sep 2014
    30
    Yep, and they are plenty big that I could use them on a much larger system in the future with some multi start screws
    This one is big enough to build guitar bodies/necks and some other fun stuff!
    Sep 2014
    30
    Got the enclosure up on the wall and the computer is out in the garage. I've got some major cleaning to do! There are several cross braces to put in yet and I still need to get the spoil-board in. Then there's wiring. I have a .050" thick piece of ABS that is 2" wide and several feet long that I'm going to use for a cable drag along the x-axis. The Z axis will have a piece of reinforced 3/8" OD push to connect tube that I will zip tie the wires to. With 3 kids 5 and under there's not a ton of time to work on this thing!
    Sep 2014
    30
    o I hooked the control box up quick. Wiring still needs to be finished but I was able to run a few jogs with the hand controller. Kinda cool!!!!
    DSCN4371 - YouTube
    Sep 2014
    30
    Some more wiring in place. wire ties are loose and wires are not in tight yet as I still have to run my limit switches. I haven't quite figured out the brackets for that yet
    Sep 2014
    30
    doh, broke a 4-40 tap....
    got 4 out of 6 limit switches installed. going to have to figure out what inputs those correspond to on the USB part of the BOB
    Sep 2014
    30
    woot, the limit switches are hooked up and work. I need to get the relay for the router set up and then button up the wiring and install the spoilboard
    Sep 2014
    30
    Made my first cuts today A big ruler to measure the boys as they grow up. Got the machine running pretty slow at the moment. I really want some multi start screws on the X axis now!! I get a bit of whipping with it as it sits if I crank the speed up too much.
    CNC router in action - YouTube
    Kept it simple for the first thing made.
    Sep 2014
    30
    I printed up some new idlers (the other ones wobbled badly) and it really reduced the movement of the screws. I should be able to bump up the speed quite a bit
    Sep 2014
    30
    Already cut my first piece of fixture over the weekend.... Thankfully it was just a chunk of 1/4" washer that was holding down the edge of the work piece. Lesson being to be sure of you workpiece zero position!
    Sep 2014
    30
    I scored some more stuff from the shop at work. They were throwing out some timing belt and pulleys. Stuff from WB-Berg. A .5" pitch belt for the X axis with a .2" pitch belt on the Y-axis. I'll eventually convert the Z to a ballscrew but this ought to really speed up my machine. I'm running 1/2"-10 single start acme screws right now and really have to spin them fast to get 50 ipm.
    Here's what I'm looking to do. It should fit nicely and actually clean up the footprint on my machine. It will have a belt on both sides of the bed for the X-axis and I'm going to double up the belts on the Y-axis to minimize stretch.
    Sep 2014
    30
    So after checking the belt length, but regretfully not before making a bunch of brackets, I found that the X-axis belt wasn't long enough to do both sides with the design above so I'm moving the motor to the gantry.
    So here's the 3d model of the X-axis motor on the gantry. I have most of the parts finished for it and need to buy one more pulley as I only have 1 right now. I'm doing a 2:1 speed reduction off of the motor. At 100 IPM I should get around 90 lbs of force on the X-axis and around 50 lb on the Y-axis. Should be plenty for this smaller machine. I'm running the belt where the X lead screws use to run and through the mounting hole for them. That way I can adjust tension and position from the ends of the machine easily.
    The Y-axis belt is installed and needs to be tensioned but that's easy to do with a short piece of 8-32 threaded rod. Then I will tighten down the clamps and install the motor.
    This one shows the jack shaft and one of the pulleys from the bottom of the gantry:
    Here is the idler pulley configuration. They should line it up nicely with the belt clamps on the end of the machine. The 0.5" pitch Flex-e-grip belt is rated for around 300 lbs and has a pair of 1/16" steel cables through it so there shouldn't be a whole lot of stretch.
    And this is what the X-axis belt clamps look like
    Sep 2014
    30
    Here's the side of the gantry with the x-axis motor mounted:
    Y-axis motor and the belt configuration
    And the Y-axis motor mounting
  1. Machine scrap yard in Seattle area?
    By Darren_T in forum DIY CNC Router Table Machines
    Last Post: 05-14-2011, 10:16 PM
  2. Thanks to Eric @ Tormach
    By tikka308 in forum SprutCAM
    Last Post: 12-06-2010, 08:55 PM
  3. Help me with this scavenged motor please
    By lagfish in forum Servo Motors / Drives
    Last Post: 01-25-2008, 06:13 PM
  4. Scavenged Transformers - Amp Rating?
    By cbcnc in forum CNC Machine Related Electronics
    Last Post: 06-30-2004, 03:32 AM
