I am using artcam pro 2008 and exporting to mach 3 to run my router. In my drawing the corners are 90 degree perfectly square. When I create a 2d profile tool path in artcam it is rounding the corners in the toolpath preview. If I select machine along vector it will square the corners but it does not compensate for the tool with and just centers the cutter along the vector. I need square corners with tool radius compensation. I have CV mode turned off in mach3 so I know that is not it.
