587,999 active members*
4,755 visitors online*
Results 1 to 13 of 13
    Oct 2004
    85
    New power supply question?
    I am now running the stepperworld FET-3 controller with a 12v @ 13Amp computer power supply with 1.5 ohm 50watt power resistors.I just bought a Lambda Power Supply model # FS-600A048 it is 48v @ 13Amps.My question is what power resistor (ohm / watt) should I use with the new 48v power supply(Lambda Power Supply)? The motors are 4.5v 1.4amp steppers.
    Aug 2004
    2849
    You should limit the current to each of the stepper phases. R= V/I 48/1.4 = 34.4 ohms....at least 100 watt resistor....I bet that will be expensive...you don't mention how you'll wire this, but the phase pairs will need their own resistors (minimum of 2 resistors per motor).
    May 2004
    198
    Quote Originally Posted by Redline
    Can the driver board accept 48VDC???
    Dave
    Oct 2004
    85
    Thae board will handle 50 volts DC.I now have the centers wired together going through 1 single 1.5ohm 50watt resistor.12volts 12amps.Is there a better solution to pick up speed using this power supply.With the FET3 I can only get 11ipm with the 12volt power supply.Is there somthing else better that I could easily swap boards and not mess with the motors and such.
    May 2004
    198
    The spec sheet says 35V continous and 50V at start up.
    Dave Rigotti
    www.hobbycnc.com
    Aug 2004
    2849
    What are you using for a leadscrew??
    Oct 2004
    85
    Stainless all-thread.
    Feb 2005
    750
    Arent those Lambda's switching supplies?
    Halfnutz
    Aug 2004
    2849
    Redline....meaning a stainless threaded rod with how many threads to the cm....this is most likely where you'll get the most improvement...unless you get some massive steppers instead.
    The best option would be to get either the HobbyCNC or Xylotex Unipolar Chopper boards. You'll have to solder them yourself, but they're under $100. The 48V supply won't work, though. You'll want to use 24V-36V.
    Feb 2005
    750
    Wont the switching type power supplies conflict with the drivers? I dont think that the Lambda is a simple un-regulated supply. I was told that the curent regulating circuitry in that type of supply will cause conflicts with the driver. In other words the driver is trying to regulate the current with a PWM circuit and the power supply is also trying to maintain a constant current to the motor and problems occur. Am I wrong about this?
    Halfnutz
    I have a Xylotex that works fine with a switcher. Xylotex even sells and recommends switchers. I think the low current draw makes it OK to use them, where Gecko's can draw much more current which could cause problems. Just realised you're using it with the FET. I don't think it will hurt anything. If anything, you may just take a performance hit. I could be wrong, of course.
    Apr 2005
    421
    These guys sell a 28vdc/6amp 12v/1amp regualted toriod PSU full assembled for $49
    http://www.cadcamcadcam.com/index.as...PROD&ProdID=66
    I am no way affiliated, nor have I purchased one of the these, but it seems very reasonable.
