Has any used or found a way to control the spindle speed via, mach 3 and
break out board and some kind of servo motor to a Router Speed Control box?
You could mount a small stepper to the speed control to turn the dial.
Something I've thought about also. Problem is it takes a full axis away. I want to make an ATC, and to do this I figure I have to use 3 axes. 1 to move the dust shoe up and down, 1 to swing it out of the way and 1 to rotate the tools into position.
Did I read somewhere that control of big dog spindle speed is done with PWM? If so I can make a linear actuator that would use simple small dc servos and this signal.
Steve
DO SOMETHING, EVEN IF IT'S WRONG!
Thanks, sometimes I can't see the obvious solution.
Steve
Our toolchanger at work has each tool mounted to a cylinder that moves it under the spindle, and the dust collection brush on the tool change side is lifted by an air cylinder.
