586,263 active members*
3,847 visitors online*
Results 1 to 19 of 19
    Aug 2019
    9
    Engraving mild/hot rolled steel ideas?
    I'm looking to engrave a small logo 1" in size into mild/hot rolled steel. Doesn't have to be very deep. I've looked at lasers but I would need a fibre laser. A CNC mill might work but not sure. My budget is 1k so I know I'm limited. Any other ideas?
    Mar 2015
    410
    Re: Engraving mild/hot rolled steel ideas?
    A pencil grinder in the lathe toolpost and a CNC controlled lathe.
    Aug 2019
    9
    Quote Originally Posted by hfjbuis View Post
    I don't think a lathe would work. I forgot to mention that the logo is small but the piece of steel is 16"x16".
    May 2003
    323
    Quote Originally Posted by Frizzo View Post
    Can't send you dm
    I have fiber laser.
    Sent from my MHA-L29 using Tapatalk
    Aug 2019
    9
    Quote Originally Posted by ChrisW View Post
    Can't send you dm
    I have fiber laser.
    Fibre lasers are out of my price range.
    May 2003
    323
    I can engrave it for you.
    Aug 2019
    9
    It's ok, I'm looking for my own machine.
    May 2003
    323
    I have co2 Engraving you can use Cermark spray to engrave in black
    You can buy these under 1k
    Or
    This
    https://gtschmidt.com/pin-marking
    Aug 2019
    9
    Or
    This
    The dot peen machines look interesting but prices range so much. Stuff from Chinese is around 1k but I wonder how good they are?
    May 2003
    323
    Etching
    https://youtu.be/ncWXVOzNGbA
    May 2003
    323
    Reverse logo stamp.
    Aug 2019
    9
    Reverse logo stamp.
    Do you know what material the stamp would have to be made of?
    Would a stainless steel stamp work?
    May 2003
    323
    Yes stainless would work also
    May 2003
    323
    This one was mild steel
    Aug 2019
    9
    Would a stamp made of stainless work on mild steel?
    May 2003
    323
    I suggest tool steel and heat treat then it should work
    May 2003
    323
    I can do it on hardened tool steel.
    Aug 2019
    9
    Aug 2019
    9
    How many tonnes of force do you think is needed to stamp A36 hot rolled steel with a 1" stamp?
  1. cut mild steel?
    By dharps in forum DIY CNC Router Table Machines
    Last Post: 04-01-2011, 03:33 AM
  2. Hot rolled steel plate needed....
    By REVCAM_Bob in forum Community Club House
    Last Post: 08-09-2008, 03:05 PM
  3. Mild Steel
    By MBG in forum MetalWork Discussion
    Last Post: 03-09-2007, 11:20 PM
  4. Stainless Steel / Aluminum Cut and Rolled
    By ukchris in forum Employment Opportunity
    Last Post: 01-18-2007, 03:09 PM
  5. Machining A36 Hot Rolled Steel
    By SurfRunner in forum MetalWork Discussion
    Last Post: 10-31-2006, 08:13 PM
