Given the wireframe version of the model, it is possible to create surfaces directly from those edges, to create a surface model. I think that is what they mean by the term 'hybrid modeller' which can model either as surfaces or as a solid.
Even while creating surfaces from boundaries, sometimes you need to use your artistic sense to determine what kind of surface is actually contained within those boundaries. In OneCNC for example, you can create surfaces from edge boundaries if you so choose. It would still be quite the task to do it, because they would be done one at a time. However, it would not be as bad as starting from scratch with solid modelling that aircraft.
