588,221 active members*
4,038 visitors online*
    Feb 2008
    5
    Left Hand Threads
    I do not currently own a lathe, but am looking to make a purchase in the near future. One of the operations I'll need to do is cut LH threads. Is this a standard lathe capability, or is there some special feature I'll need to look for?
    Thanks in advance,
    Larry
    PS: Since there doesn't seem to be a lot of old American iron available in my area, I'm currently looking at one of the benchtop Chinese or Taiwanese machines
    Jan 2008
    136
    yes, it is standard, you will only need to invert the tool and run the feed away from the spindle at the correct pitch.
    Oct 2005
    1237
    running the tool away from the chuck will make a right hand thread. Invert the cutting tool, reverse the direction the part turns and feed towards the chuck.
    Feb 2008
    5
    Thanks for the help.
    Larry
    Mar 2005
    1136
    you guys are making it complicated, reverse the feed and leave the tool right side up and your left hand thread will cut from headstock to tailstock. compound at 29.5 to the left and grind a left hand tool - the helix angle is in the opposite direction so the clearance angles have to lean the opposite way.....in answer to Q, yup standard stuff.
  1. How do you turn a Left Hand Inside Dia. Threads
    By rapidtraverse in forum Haas Lathes
    Last Post: 02-11-2008, 08:50 PM
  2. Why do you use your left hand
    By ImanCarrot in forum MetalWork Discussion
    Last Post: 10-15-2007, 12:14 PM
  3. Left Hand End Mills
    By Medway Man in forum MetalWork Discussion
    Last Post: 10-08-2007, 07:47 PM
  4. Left hand cutters
    By DAB_Design in forum MetalWork Discussion
    Last Post: 11-03-2004, 04:23 PM
  5. coverting from Right-hand to left-hand coordinate system
    By eltonr in forum Uncategorised CAM Discussion
    Last Post: 10-15-2004, 02:40 AM
