588,215 active members*
4,078 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Defining stock shape
Results 1 to 7 of 7
    Apr 2005
    14
    Is there any way to define in MC (MC9 Router or Mill) custom stock shape? If I want to mill a pyramid, and my actual stock shape looks close to pyramid, how do I define it in MC to avoid unnecessary air cutting? Or there may be a way to suppress toolpaths to some custom geometry?
    Any help highly appreciated,
    Joe
    Oct 2004
    116
    Joe,
    I would love to see this one answered myself. I have used other cad\cam packages, and MC seems to be behind the others in this aspect. If the option is there, then it's not easy to find.
    Apr 2005
    14
    Thanks for reply dmealer,
    So for now I am stuck with drawing boundaries smaller at the top, increasing in size towards the base of pyramid, and creating roughing programs for each of them.
    Apr 2003
    1876
    You can't define anything besides square and round stock in Job Setup.
    BUT... you can use an STL file for the stock shape. After you create the SLT, go to Verify, click the configuration button, click FILE from STOCK/SHAPE, then open the STL from the STOCK FILE box.
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    Oct 2004
    116
    This is true Red, I do it all the time. But can you get MasterCam to use this stock in it's calculations for it's tool path? Any stock you define, STL or not, seems to be just for represntational purpouses only.<Spelling stinks....LOL. I have used software that will start calculating the tool path from the edge of whatever stock you have set for it, so you don't have to alter depth cuts or other attributes to get the path you are looking for.
    Dalen
    Oct 2009
    Hİ,
    I am using mastercamX.
    At Rough Flowline operation I cant define stock.
    I am writing stock parameters but Mastercam didn't use stock.
    Tool must starts operations on top of stocks, but tool starts operations top of part.
    How can define stock?
    And I want to define stock with stl file.
    I can load stl file but mastercam doesnt use this stock.
    Tool starts operation top of part.
    I want to machine to cast iron.
    I must define amorph shape stock.
    And mastercam must use this stock.
    How can I do?
    Thank you very much.
    MastercamX (10.0.12.2)
    Dec 2008
    3137
    When you open the "Drive Geometry" dialog box
    you can seclect/deselect surfaces or faces
    there is also a button "CAD", this is for you to select 1 CAD file ( usually a STL of every thing done up until this operation )
    Before running verify, set STL resolution to be a coarse setting.
    If you set the STL accuracy too fine, as it will give memory allocation errors when using the STL in toolpath calculations, or it will take a long time to process
  1. Who has stepperes in stock?
    By LeeWay in forum DIY CNC Router Table Machines
    Last Post: 03-27-2006, 03:23 PM
  2. head stock and tail stock chucks
    By mocnc in forum DIY CNC Router Table Machines
    Last Post: 10-20-2004, 03:16 AM
  3. Quick release tail stock on 8x12 lathe
    By balsaman in forum Mini Lathe
    Last Post: 10-12-2004, 01:41 PM
  4. Finding metric stock
    By Konstantin in forum MetalWork Discussion
    Last Post: 09-12-2004, 05:28 PM
  5. straightening warped aluminum stock
    By bzo in forum MetalWork Discussion
    Last Post: 06-26-2004, 01:57 AM
