588,591 active members*
11,778 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Mini Lathe > Home Made internal spindle stop!
Results 1 to 9 of 9
    Cool Home Made internal spindle stop!
    I have been doing a lot of repetitive tasks on my new lathe, so I decided its time to make a nice solid stop to go inside the spindle bore!
    Cool
    So I grabbed a piece of 2" diameter 1018 steel and turned it to fit the inside diameter of my spindle, around 1" long. Bored a .750 through hole for the stop-shaft.
    Then I faced the other end to make a flange 1/2" thick.
    Cool
    Next I drilled a cross hole around 3/8" diameter through both walls of the small diameter.
    Then I put a pin through it and leveled it in my vise, so that I could run a metal slitting saw through the flange and into the cross hole.
    This will allow the hub to flex, and not break from repetitive use!
    Cool
    This whole project was not without incident, as you can see from the images it cost me a 7/8 5C collet!
    The arbor grabbed and spun in the collet, and cracked the side out of it!
    The saw is 6" diameter, 1/8" thick running at 70-RPM
    Cool
    All though the collet cracked, I did manage to finish the cut in the hub!
    Then I drilled and tapped a 1/4-20 hole through one wall of the large diameter, this is for a set screw to clamp on the stop-shaft, and expand the hub inside the spindle bore!
    This way I kill two birds with one stone!
    I put it in my spindle, and ran it at 2000 RPM, it did not cause any vibrations which is good news!
    Now I can make small ACME leadscrews all the same length with out having to do extra setups for each one!
    My 14x40 lathe has a 1.6" ID in the spindle, so I used a 3/4" shaft to make it solid! Then I turned one end of the shaft and pressed a block on to it, and turned it to slip freely inside the spindle bore. This gives me one complete flat surface to stop my parts from, wether I use a 3 jaw, 4-jaw chuck or a 5C collet chuck!
    Hope this gives you some ideas of how easy it is to make a spindle stop!
    Eric
    Attached Thumbnails Attached Thumbnails 000_0623.JPG   000_0624.JPG   000_0625.JPG
    Cool
    Now its off to eBay, to bid on a replacement 7/8 R8 collet!
    Jun 2003
    1365
    looks good, I ended up just turning a peice with a light press into the end of my spindle and use a peice of threaded rod with a jam nut, worked pretty good for the parts I was making, I made about 60 standoff posts that all came out within .001 or less.
    yours looks a bit better than mine, definately better concept
    Jon
    Feb 2006
    1187
    Widgit you are the man. You are always coming up with somethin' kool that we can all use and enjoy, my hat goes off to you , ALL BOW to the Widgit Master !!!!
    Jan 2008
    8
    Re: Home Made internal spindle stop!
    I made these for our small CNC lathes.
    Attachment 330686
    The drawbar (tube) doesn't allow for a spindle stop that's fixed in the spindle (moves back and forth so there's no accuracy). These are attached to the chuck.
    For the bigger machines, I made an adapter plate to be used with these small stops
    Attachment 330688
    We are about to design new ones for the larger lathes now. Same idea but different design.
  1. Spindle Choices and Home Made CNC
    By maly-miller in forum Uncategorised MetalWorking Machines
    Last Post: 03-19-2014, 03:28 PM
  2. My desktop cnc with home made spindle
    By RMHCNC in forum Open Source CNC Machine Designs
    Last Post: 12-04-2013, 03:18 AM
  3. 100000 rpm spindle home made
    By goldi80 in forum Hobby Discussion
    Last Post: 10-14-2011, 03:43 AM
  4. My home made cnc - Need a good spindle?
    By Rajpage in forum DIY CNC Router Table Machines
    Last Post: 11-02-2010, 09:03 AM
  5. Home Made Vise Stop - For 6" Kurt Vise
    By widgitmaster in forum Bridgeport / Hardinge Mills
    Last Post: 12-15-2006, 03:49 PM
