I would like to know if it is possible to increase the number of characters per line. My font size is only .150 in and I can only place 30 characters per line.
the question is how to place up to 100 characters per line?
Program F-engrave. I need to be able to place .200 size fonts in an area of 2.00 high by 4.00 long.
@air2gnd
When you type text into the input text box the text will continue on the same line even if it wraps to the next line in the input text box. To get to a new line you need to input a carriage return (press the Enter key).
When you click the recalculate button to refresh the display the overall size of the text will be displayed in the status bar (at the bottom of the main F-Engrave window). This is where you can check to make sure you are within your allowable space.
Also, if you maximize the F-Engrave window the input text box will get wider so your text will not wrap as many times in the input box.
Scorch
Thanks for the info. I tried it and it works!!!!!! F-engrave is GREAT.
