Everything is bio-degradable, if you run over it enough times with the lawnmower.
Normally same voltage in and out is for isolation, what it was for in this case is hard to say without knowing the circuit it was feeding.
Al.
Albert E.
Thanks for the quick response Al.
JAckal
Yes, the Shape units were filters.
