Hey guys
First a little background. I've designed and built a few CNC router tables over the last couple of years, so I'm not completely clueless. I've got a good combination of PC, driver, inverter, spindle, etc etc that work well together and are very reliable - I use my table daily.
Just before X-mas, I built a table for a friend of mine. About a month later, he tells me he has been snapping endmills because the spindle stalls while cutting. Surprised, I go to have a look. At the time, he is cutting MDF, 1/4" single edge bit, doing 1/8" deep passes at about 80IPM at 12,000RPM (IIRC). In other words, the spindle is under little load. After 4 to 5 minutes cutting, sure enough, the spindle sound changes, like it's missing or cutting out. A second or 2 later, it happens again, then about 5 seconds later, it rapidly slows down & stalls.
It's a 2.2Kw water cooled spindle with a huanyang (sp?) inverter. I programed the inverter and tested everything before he took it. I know the settings are correct, as they are the same as my table that has been running for almost 2 years with zero problems...
So we re-zeroed and ran the program again, but this time it was following the previous cut lines, so it was under no load at all, and it still stalled a few minutes into the program, but it happened at a completely different part of the program. The spindle was not even warm, and it was not seized. Pressing the F5 key turned it on again and it continued to run for a bit, then missed and stalled again. I was watching the inverter, and as the spindle slowed and stalled, the inverter display showed the RPM dropping rapidly.
So I thought lets swap the inverter. I pulled one out of my machine and put it in his, ran the same program but nothing changed, spindle stalled again. I then replaced the spindle with another good spindle, but the problem persisted. While I was at it, I replaced the driver with a known good one, but no luck. Finally, I connected up my PC to his table and ran the program again but, you guessed it, spindle still misses and stalls after a few minutes of use. We ran a different program, but it made no difference, spindle stalls after cutting for a few minutes....
All the wires are shielded, all connections properly terminated, all plugs tightened, everything is exactly the same as every other table I have built, and every table has performed flawlessly except this one.....I'm out of ideas, what could be causing this to happen?
