I'm not sure whether it is better to post this question here or in the General Electronics forum, but I'll give it a try here for now.
I'm trying to locate a suitable textbook or other source of design principles for servo drive electronics. The field is so large that it's hard to get my arms around it and know where to start, and so I hope that someone might be able to direct me to one or two sources that are considered the 'bibles' of servo drive design, or that start with a gentle introduction and dive in to the deep end from there.
I have a non-CNC application for which it is possible that a circuit based on servo drive electronics principles could be the answer. I am not an EE, but I do have some background in electronics and some math, so I'm not afraid to get my hands dirty.
I could be wrong in my assumptions about the suitability of servo drive principles to addressing my needs. For my application I'm hoping that servo drive reference circuits exist that are capable of driving very low impedance loads (for example, milliohms or tens of milliohms) at low audio frequency rates, perhaps as low as a few Hz up to a few hundred Hz. While I have not yet done detailed calculations, my guess is that power requirements are not very large, perhaps less than 200 watts may be sufficient with an output voltage range of perhaps up to a volt or so (I may need lots of amps, though).
Am I in the ballpark or way off base here? I'm not at all certain that the characteristics that I listed above are even typical of servo drive circuits. I'm hoping that I can find a solution that uses one or more semiconductor devices directly driving the load (perhaps through a big DC blocking capacitor), but if it is necessary to use an output transformer to drive such low impedances I suppose that I could accommodate that as well.
I am going to start my own literature search, including technical reports, device datasheets, journals and trade magazines, patent filings, and various electronics texts that have been gathering dust in my personal library, but maybe I can get some pointers here that may help guide my search.
