588,648 active members*
5,374 visitors online*
IndustryArena Forum > CAM Software > Mastercam > "ActiveX component can't create object" problem
    I am running X3 and I updated my CA security suite software to V7 (latest version).
    Since doing this whenever I try to post a program I get the "ActiveX component can't create object" message then the editor will come up blank.
    Should I try using a restore date in windows to see if the problem disappears, or do I try to repair the Mastercam Installation??
    I had the CA security online guys go through and check my firewall settings and they also tested the ActiveX and it worked fine.
    Any ideas would be greatly appreciated.
    Jun 2005
    305
    I suggest trying to repair the MasterCam installation.
    ObrienDave. MasterCam since V6. Gcode since 1983.
    The nose you punch today may belong to the butt you have to kiss tomorrow.
  1. Replies: 12
    Last Post: 06-27-2012, 12:30 PM
  2. Replies: 0
    Last Post: 11-23-2009, 11:45 PM
  3. "motor steps per resolution" and "driver microstepping" settings
    By margni74 in forum LinuxCNC (formerly EMC2)
    Last Post: 10-24-2009, 08:33 AM
  4. "J" head type "millport"(tiwan,1980) clutch
    By marksbug in forum Bridgeport / Hardinge Mills
    Last Post: 08-17-2009, 04:48 PM
  5. 40W "stamp maker" laser engraver problem
    By frgt1000 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-05-2007, 09:45 PM
