588,235 active members*
4,380 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > okuma twin turret axis flip?
Results 1 to 13 of 13
    Nov 2010
    hi, i have a problem, we are running a twin turret okuma lathe, and are haveing problems with the bottom turret cutting a inside threads, as it is cutting down. our "engineer" says we should use the second turret and cut up, instead of a simple fix of just switching some tools around to thread from the top turret. i tried to explain to him that flipping it around will be a night mare as it will reverse all the programing and offsets as the all the + would be negatives and so on... he thinks the machine will be smart enough to figure it out on his own, but i fail to see how a machine will be smart enough not to do what its programmed to do... i did some research and i found G68 and 69 which is mirror image on and off, think this would help in this situation? sorry if my explanation of all this is hard to undertsand...
    Jan 2008
    575
    [quote=fishy steve;846985]
    I don't understand what this means.
    Does he mean use a left hand tool?
    If you change any of it you are going to have to do all that anyway aren't you?
    I don't know about G68-9. I DO know that there shouldn't be any problem using your lower turret to cut ID threads. Maybe if you let us know exactly what the problem is than we could go from there. IE. Problem with the program?
    The beaten path, is exclusively for beaten men.
    Jun 2005
    142
    So what is actually the problem with threading? Is it surface finish, tool life,...?
    What form is it?
    What Dia?
    How long?
    What material?
    What condition is your lathe in?
    Apr 2009
    1262
    The Okuma Twin Spindles use G13 and G14 for A and B turret and use G140 and G141 for Left and right spindles. That being said, the SAME code can run on left, Right, A and B spindles. I know that on some Fanuc machines everything has to change, but Okuma did a really nice job on their software. Even the chucking commands, coolant commands, nose comp, Lap cycles, Milling cycles, etc. will work properly. You can even CALL a subroutine and run it on either spindle.
    So your "engineer" is mostly right. You will still need to touch off a new offset depending on what turret and what spindle mode you are in.
    The threading should be primarily the same no matter which mode or turret you are using. Please be more specific on the problem you are experiencing and check the basics such as tool centerline, stickout, etc.
    Best regards,
    Sep 2008
    Lower turret threading
    We used a lot of 4 axis Okuma's for threading. Is the problem chips rolling to the bottom of the part and chipping out the tool? If this is the case your eng is right.Using the top turret will keep the insert away from any chips gravity is pulling to the bottom of the part.
    Mitch.:cheers:
    Aug 2010
    When using OKUMA DOUBLE TURRET Lower turret don't have High pressure coolant. Upper turret have high pressure coolant, Tht's why any operation use upper turret come out chips from the part.
    While running any threading chips never broken because you can not change feed rate. Feed rate is depends on the thread pitch.
    When doing threading operation more chips rolling on the part, you put Mid on Manual and single block and stop spindle. Then remove the chips from the part and cycle start release mid on manual, single block also. Then you make a good thread.
    Feb 2009
    6028
    You haven't really lived until you've done a 4 axis Acme thread! Helped set up a shop years ago, lots of pucker factor that first part !
    Jan 2008
    575
    Quote Originally Posted by underthetire View Post
    Ok I quit , what does this mean? It's still single point. Do you mean because of the huge chips, and doing OD and ID at the same time? :withstupi
    Feb 2009
    6028
    Quote Originally Posted by littlerob View Post
    Actually, It was upper and lower turret threading the inside of a ring. Since one turret was always threading 180deg before the other turret, we ran a smaller tool for roughing on the upper and the correct size on the lower. Still single pointing, just X2. That was about 1991, on a LR-15BB, with 250PSI coolant.
    Jan 2008
    575
    Makes sense now, you start the turret that is finishing 1/2 af one lead further out. Very close turrets especially when retracting. HMMM Sorry for the hijack Steve
    Feb 2009
    6028
    Thats why we came up with the Beaver Tail ( as a joke ). Was two pieces of thin copper with doubleside tape and wires comming off. You basicaly stuck one sheet per side on the inside of your ass cheek so when you really puckered it would E-stop the machine.
    Jan 2008
    575
    @ UTT. Man I wish the "beavertail" were implemented with all new operators, pucker activated E-stop, where are the bio-mechanichal engineers when we need them?
    Apr 2009
    1262
    Oh c'mon...everyone knows if you use a sphincter switch you'll gain .25 second reaction time over a "beaver tail"!
    Steve - you still with us? Betcha wisha weren't. (flame2)
    You gotta love the high tech discussions going on here and the technical knowledge you are gaining...
    Best regards,
  1. Replies: 10
    Last Post: 05-04-2023, 11:04 AM
  2. Replies: 4
    Last Post: 10-02-2014, 04:58 AM
  3. OKUMA LU-15 B Turret problem
    By CNC_Tools in forum Okuma
    Last Post: 08-21-2010, 11:24 PM
  4. Looping twin turret programs
    By anyfish in forum Okuma
    Last Post: 05-07-2010, 03:32 PM
  5. DOOSAN Z290SM TWIN TURRET LATHE
    By CHAD LAWSON in forum Daewoo/Doosan
    Last Post: 01-22-2009, 03:25 PM
