588,268 active members*
12,100 visitors online*
IndustryArena Forum > CAM Software > SolidCAM for SolidWorks and SolidCAM for Inventor > SolidCam + Mach3 50+ Parts - pattern (Offset) etc...
Results 1 to 12 of 12
    Nov 2010
    13
    Question SolidCam + Mach3 50+ Parts - pattern (Offset) etc...
    Hi, first post here, need help for SolidCam part pattern, if it's possible of course...
    So the thing is I have plastic sheet (1200x600mm), from that sheet I need to get 50 smaller pieces (50 exact the same toolpaths),
    At first I thought that I would use Mach3 offsets and use sub program of same toolpath, but I cannot get it working - its so simple but so complicated at the same time. First - Mach3 decides to clear second (G55) offset value and much more problems.
    So what would be the best solution for this specific job? I thought maybe SolidCam has "pattern" or pre processor Offsets?
    Any ideas? Thanks.
    Nov 2010
    13
    Re: SolidCam + Mach3 50+ Parts - pattern (Offset) etc...
    Just had an idea:
    What if I useSub-Program, reset axis on each part and at program end return to first part start position - First mill one part at X0Y0, then move axis to second part zero position, zero X and Y axis and use sub-program again at X0 Y123, then X123 Y0 etc...
    Any ideas?
    Oct 2013
    64
    Try to use g91.
    Oct 2013
    153
    Transform command in solidcam will do that for you . Just create the tool path for one piece and use the transform option as you want either circular pattern or rectangular
    Nov 2010
    13
    Before I started to work, at this moment I have one piece drawing with complete toolpaths, can I transform it without redrawing complete sheet with 50 peaces? Or SCAM must have transform part? Maybe extending Stock is enough?
    Oct 2013
    153
    No need to have a transform part . For stock if you want to see the simulation you need to extend the stock size . Select all your operations right mouse click then select transform from the drop down menu . Use translate\matrix\ then just fill up the Columns on the box
    Oct 2013
    64
    You can do it with transform command.
    Nov 2010
    13
    Everything is clear until "fill up the columns on the box" If I select all operations, in list appears "Multiple operations..." If only one - that operation name. Right click - I can add matrix etc but if i enter matrix count and click OK it doesnt do enything, click OK again to apply transform, nothing happens. ?
    Nov 2010
    13
    Attachment 250072
    This is what I get
    Oct 2013
    153
    you should see like thisClick image for larger version.
ID:	250088Click image for larger version.
    Nov 2010
    13
    Pretty dumb mistake Didn't set X - Y steps. Thank you! Works like a charm now. Will see how Mach3 eats that g-code
    Nov 2010
    13
    So here we go again,
    I have problem that I need to drill and pocket each part individually, using transform I get every single operation on all 50 parts, (drills holes in each part, just then makes pockets etc..) What I need is to drill, pocket one part, then drill pocket another.
    Any suggestions?
  1. Newbie - Solidcam and Mach3
    By beluga282 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 07-19-2016, 12:56 PM
  2. Replies: 3
    Last Post: 07-13-2014, 11:19 PM
  3. Multiple identical parts in a pattern
    By Molsongr in forum G-Code Programing
    Last Post: 06-17-2014, 05:22 AM
  4. Mach3 5axis Solidcam
    By solidcamx in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 03-20-2014, 04:49 PM
