588,653 active members*
7,005 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > alarm 105 (z servo error toll large) on Haas VF-OE
    Jul 2008
    27
    My Haas VF-OE have a problem. I can't zero return all axis. Alarm 105 (Z servo error too large) appear when home Z axis. Now, spindle is very near table. Pls help!
    Thank you!
    Jun 2007
    Alarm 105
    Check the pressure on the hydraulic conterbalance for the spindle. It should be about 750 psi. If it's much lower than that, the Z servo won't be able to lift the head.
    Meanwhile, wedge a solid block of wood under the spindle so it doesn't contact the table.
    Jul 2005
    12177
    Did this happen when you tried to zero return the axies?
    I think you should check the microswitch that detects the Z home position. If this microswitch sticks the Z axis will go all the way to the end of its travel and alarm when it hits the stop on the end of the ballscrew.
    The counterbalance pressure will not change this and the spindle itself cannot travel far enough to touch the table.
    Aug 2007
    Hello
    Quote Originally Posted by hoi.le View Post
    Thank you!
    I have table alarm of Haas. I hope, this can help your.
    Attached Files Attached Files
    Jul 2008
    27
    Lightbulb
    Quote Originally Posted by Geof View Post
    Yes, that's right, Geof!
    the Z axis microswitch fault when travel from USA to Vietnam.
    Thank you very much!
  1. 434 servo alarm: Z axis detect error
    By padobranac in forum Fanuc
    Last Post: 12-21-2021, 03:18 PM
  2. ALARM shuttle drawbar alarm haas
    By timmydabull in forum Haas Mills
    Last Post: 02-18-2013, 07:47 PM
  3. Replies: 6
    Last Post: 04-29-2011, 11:20 PM
  4. Replies: 12
    Last Post: 03-15-2010, 02:19 AM
  5. Tidal Waves Death Toll Rises to 44,000
    By cncadmin in forum Community Club House
    Last Post: 01-03-2005, 09:29 PM
