- New DSP Control System
- Independent DSP system, work without a computer.
- Insert TF memory card, automatic reading and processing files.
- By operate the control box, you can program and carving directly.
- G-code files can be directly edited, delete, insert, and so on
Machine Structure Highlights
- USB interface
- Balls crew made it a higher precision
- Limited switches added
- 2200W water cooling spindle
- 4th axis can be Plug-and play, no need to replace controller box.
- Auto-Checking function, easy to set origin of Z axis
- Built-in frequency converter in control box
- Compared to smaller machines, it has a broad base and a thicker screw
China Mini CNC Router Machine Manufacturer Excellent Service
- Got CE approved.
- From reliable & trustable profesional China Mini CNC Machine manufacturer.
- Youtube cnc machine video support.
- Technical team always available.
- English manual available.
Shape dimension X860mm*Y630mm*Z480mm Max.workpiece dimension X600mm*Y900mm*Z100mm Frame materials aluminum alloy 6063 and 6061 the unique and dedicated mold extrusion profiles. let counterfeiters dwarfs Acceptable material thickness ≤100mm Driving units X: 1605 ball screw Y: 2005 ball screw Z: 1605 ball screw Sliding units X: Dia.30mm chrome plate shafts Y: Dia.30mm chrome plate shafts Z: Dia.16mm chrome plate shafts Stepping motor type 57-76 two-phase 3A 150N.cm Spindle motor brand new 2.2kw water cooling spindle, 24000RPM Spindle collet ER16-A, 3-10 mm shank diameter tool Repeat accuracy <=0.05mm Spindle precision Radial beat acuities 0.03 mm Carving Instructions G code/ TAB files/ nc file/ NCC files Maximum speed 4000mm/min Carving speed 0-2500mm/min (different materials differ) Command code G code Protection Emergency stop button Operating Voltage AC110V/AC220V
New DSP System 600*900mm Working Area 3D Desktop DIY CNC Engraver Machine for Sale
