587,998 active members*
1,683 visitors online*
IndustryArena Forum > Other Machines > Engraving Machines > Engraving Advise Needed
    Sep 2007
    11
    I would like some help on what tools I should use for engraving. I have a small CNC mill which can run at 3600RPM. I use the RhinoCam software to create the toolpaths/G-code. For engraving text, what would you recommend for engraving bits? I have tried using dremel bits with a ball nose but I either break them or the text is sloppy. My engraving is always done on a flat surface so nothing fancy.
    I generally use 6160 aluminum but will be doing some mild carbon steel too? If you have help, please let me know.
    Use a one flute Carbide Engraving tool. Most machine shop suppliers stock them.
    Dec 2006
    77
    another good resource is www.2Linc.com. nice selection at reasonable prices.
    Sep 2007
    11
    What do you recommend for shape of cutter for general text?
    Aug 2005
    191
    I'm assuming you are engraving in steel since you are using a mill. Use a 60 degree included angle split point (single lip) carbide cutter with about 25 degrees relief clearance , 5 degrees side clearance,and 10 degrees back clearance. 3,600 rpm is a little slow, but doable; just reduce tool feed to compensate. Antaresinc.net has a wide selection of cutters and lots of information on choosing the right one for your situation.
  1. Selecting the right CNC Mill - Advise needed
    By Rich05 in forum Uncategorised MetalWorking Machines
    Last Post: 05-24-2007, 02:18 PM
  2. Newbe - Calabration advise needed
    By deleteallusers in forum G-Code Programing
    Last Post: 05-04-2007, 04:19 PM
  3. Advise for Heidenhain needed
    By Oopee in forum Uncategorised CAM Discussion
    Last Post: 08-04-2006, 04:16 PM
  4. Cleaning Up vector files for CNC Engraving? Advise Please
    By Bretto in forum Uncategorised CAM Discussion
    Last Post: 07-25-2006, 08:26 AM
  5. Advise Needed
    By glbreil in forum MetalWork Discussion
    Last Post: 04-03-2006, 11:13 PM
