588,468 active members*
4,926 visitors online*
IndustryArena Forum > Community Club House > International / Regional Forums > Canadian Club House > I need 6 inputs, but my breakout board has only 5, how?
Results 1 to 8 of 8
    Oct 2009
    16
    now, I need 6 inputs for the limit switches (X++,X--,Y++,Y--,Z++,Z--), but there is only 5 inputs on my breakout board, what should I do?
    To buy a second breakout board and use the second parallel port?
    or may I use all these 6 limit switches to setup on the same pin, say, pin 12? It seems OK since all limit switch will trigger the E-stop. Am I correct?
    thanks
    Feb 2007
    4553
    Lucky021,
    Mach3 can share one input pin for all limits.
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Oct 2009
    80
    Quote Originally Posted by lucky021 View Post
    yeah
    If they are normally closed, wire in series. Normally open, wire in parallel.
    NC is preferable if you have both terminals.
    http://www.plasma777.com/driver/xylo...cnc_plasma.htm
    I just got my first CNC machine (Zenbot 1216) and was looking at that issue as well. I know that I can setup home switches with Mach3 and these can be in common with a limit switch on each axis. Can the other 3 limit switches share one parallel port pin?
    Yes.
    Yes.
    Thanks for that confirmation. My driver board also has the capability to take inputs from the limit switches (though, just one input each for the pair of ++ and -- limit switches). I was wondering if I should also try to wire in the limit switches to the driver board as well, or if providing the switch inputs to Mach3 would be better/sufficient.
    Apr 2010
    294
    If you wire the limit switches to the driver board, you might have a problem jogging back off the switch. Mach3 has an override to let you do this, but if the switch disables the driver board how are you going to move away?
    Wilfrid
    Quote Originally Posted by UUU View Post
    Good point. I wonder then why even have the input on the driver board.
    I found this wiring diagram, which was mentioned in another thread, that looks to be helpful. Maybe it will help the OP as well.
    http://pminmo.com/PMinMOwiki/index.p...limit_switches
  1. plutp-P board encoder inputs
    By visky in forum LinuxCNC (formerly EMC2)
    Last Post: 04-23-2010, 07:44 PM
  2. C10 breakout board
    By csmoak25 in forum Automation Technology Products
    Last Post: 03-19-2010, 06:16 AM
  3. which breakout board
    By daisydog in forum Controller & Computer Solutions
    Last Post: 06-22-2009, 02:11 PM
  4. Breakout board, Relays on board?
    By Cooper in forum Open Source Controller Boards
    Last Post: 06-10-2007, 01:55 AM
  5. Breakout Board
    By bkkpool in forum CNC Machine Related Electronics
    Last Post: 07-28-2006, 07:15 PM
