I have no idea how many hours I have now wasted trying to figure this out. I have searched here and via google and can not figure this out. I am able to "transform" tool paths from view to view (top to bottom) via a combination of check boxes I screen printed a while back and it actually turns the tool paths over to cut on the bottom, but I can not get the "mirror" to flip over into the new view. (on transfer i just keep clicking points until it finally lines up...)
I am attaching a test part that I made. I have tried literally hundreds of combinations and can not figure it out. I am trying to use "transform tool paths" and every combination I can think of. I am just trying to mirror the paths to a g55. I created the bottom wcs with the origin in the same location after the part is flipped.
HELP. If someone can flip the paths so i can see what checks they used and maybe explain if I am screwing up something with the WCS would help a LOT.
I already cut the parts by just creating new geometry on the bottom and making all new tool paths to get it done, but it took forever compared to how I think it should work.
This is on X5. The original part was made in SW11 so I created this simple part to see if it was due to importing and messing up WCS, but it seems to do the same thing... reassuring as that means at least I know THAT wasn't what I did wrong.
