588,141 active members*
6,016 visitors online*
Results 1 to 6 of 6
    Jan 2008
    my new 3 axis driver wont work
    Hey guys,
    I just purchased a new 3 axis 2 phase driver and when i hook it up it doesnt work. I used the correct voltage for the driver.
    I installed mach3 using windows XP and the installed driver correctly but still cant get it to work.
    is there anyway i can test the printer port pins from to computer for a signal?
    or anything else i can do?
    Any thoughts?
    May 2006
    138
    Take a DMM/voltmeter to the pins on your computer that determine direction since they won't be changing as quick. I believe it's a 5V signal. Just hook the red lead to the pin that does direction and the black lead to a ground pin.
    On the board you could measure if there's voltage going to the motor (this is probably the first thing you should do). If you're not getting any (which seems likely), and you feel comfortable opening up the driver, try testing different points on the board, namely the output of the driver's main chip.
    Also, do you smell anything burning? A weird stench of sorts? If so, say good bye to your driver, that means something fried a chip.
    Aug 2006
    102
    are you using a break out board or are you wired directly to the driver from the parallel port?
    Jun 2003
    3312
    Give us some details on your 3 axis board, then maybe we can help....
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
    Jan 2008
    I am wired directly to the parallel port, also when i check the voltage going to the motor its constant voltage, it doesn't change when i have mach3 running. this weekend i will check the pins on the pc.
    also here are some specs on the 3 axis driver:
    * Resolution: Full Step,1/2,1/4,1/8.
    * Support two phase 4wire, 6wire 8wire stepping motor.
    * Compatible with many CNC software such as Mach, KCAM, TouboCNC, etc
    * Max 2.5A@36V 90W per axis.
    * Built in Manual Control Function for position adjustment.
    * Built in Restriction Bit interface for X-Y-Z axis.
    * Built in 1/2 current control interface for long time running, protect motor from overheating, enable via jumper.
    i am using motors from an old panasonic dot matrix printer. from my testing i found them to be 2 phase unipolar motors.
    thanks.
    Jun 2003
    3312
    So it's a bipolar driver, what other informaion? If your unipolar motors are 5 wire motors it won't work for them.
  1. Boxford 280 Turnmaster wont work
    By flannman in forum DNC Problems and Solutions
    Last Post: 11-18-2007, 11:12 AM
  2. single axis driver and a b.o.b.,or multi-axis driver board
    By .xXACEXx. in forum Stepper Motors / Drives
    Last Post: 07-03-2007, 05:13 AM
  3. Why wont this work?????
    By epineh in forum CNC Machine Related Electronics
    Last Post: 03-18-2007, 06:44 AM
  4. just a program that wont work
    By kangarabbit in forum G-Code Programing
    Last Post: 09-03-2006, 03:38 AM
  5. Syntax or just wont work???
    By murphy625 in forum CamSoft Products
    Last Post: 04-06-2005, 01:16 AM
