588,668 active members*
5,906 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > Where do you get a shrink ring foruse with a cold forging die?
    Nov 2015
    12
    I want to build a simple cold forging die to use on an older minster knuckle press. From what I have seen, the dies are usually made by cutting a cavity in the center of a piece of round stock of D2 steel (about 3" dia) and then this round piece is placed inside the center of a second and much larger diameter steel ring (say 12" dia) that has a precision ground inner diameter of about the 3". This ring (called a shrink ring) is heated so that it expands, and then the die is slipped into the inner hole. When everything has cooled you now have your die with a high compressional force on its outside so that it will not crack.
    My problem is that making this shrink ring adds a lot of extra work and I would think that someone must make stock shrink rings for this purpose. However I have never found any suppliers that seem to have such rings listed. Maybe they are called something else? I can make a ring if I really need to, but it seems like it would be cheaper to find a stock supplier. I could also make my own allen screws and hex nuts too but obviously it is cheaper and easier to buy such items and I would think it would be the same for a shrink ring.
    Thanks for any help on this matter.
    Feb 2006
    7063
    Re: Where do you get a shrink ring foruse with a cold forging die?
    And you pose this question in the forum dedicated to Novakon CNC milling machines because......???
    Regards,
    Ray L.
    Jun 2006
    3063
    It's amazing how many posts are made to CNCZone that have virtually nothing to do with the forum. If a poster can't be bothered to make even simple attempts to see if the forum is appropriate for the question, why should members waste time providing the info sought?
    Nov 2015
    12
    Quote Originally Posted by MichaelHenry View Post
    My bad! This is the first time I have ever used CNCzone. I have no idea how my post ended up under Novakon Systems. Was not supposed to be here so somehow I screwed up. Please disregard unless you know how to delete the thread or transfer it to where it was intended to be. Sorry!
  1. Won't cold start in cold weather.
    By Unatanium in forum Fadal
    Last Post: 12-31-2015, 08:42 AM
  2. Shrink FIT
    By Ashish B in forum Linear and Rotary Motion
    Last Post: 12-30-2010, 06:49 AM
  3. Cold forging aluminum
    By Kmed in forum Bending, Forging, Extrusion...
    Last Post: 01-09-2010, 08:29 PM
  4. Shrink fit tooling
    By Dropout in forum MetalWork Discussion
    Last Post: 06-08-2009, 02:23 AM
  5. How cold is to cold for BP Series I CNC
    By jho5820705 in forum Bridgeport / Hardinge Mills
    Last Post: 12-21-2006, 02:13 AM
