587,948 active members*
3,682 visitors online*
IndustryArena Forum > CAM Software > Mastercam > i need held in making a MasterCam X3 file.
    Jan 2008
    72
    in the bottom part of this picture:
    http://www.outdoorebooks.com/ebay/webley/im-12.jpg
    how does one go about making the ramp type ratchet (on the extractor) on a 3D extruded boss in MasterCam X3?
    any help would be appreciated...
    Jan 2008
    123
    It's a little hard to tell from that picture but you need to draw the ramp geometry (it has to be a closed chain) either from the right plane or the front/rear plane then do an extrude/cut to a specified depth you can do just one ramp then rotates the geometry the correct angle
    If you have the cylinder drawn and would like to post it I give it a try and send it back
    Just looked at the pic again ..you may have to create a seperate solid of the ramp and do a boolean remove to get it to work right
    Jan 2008
    72
    Quote Originally Posted by tstom View Post
    how does one construct the ramp geometry on the extruded cylinder boss?
    Jan 2008
    123
    Once again it's really hard to tell from that picture but if you look at the side view where the ramp forms 2 sides of a triangle you would extend those lines to the right to close the triangle and then extrude that shape from either the left of right plane then from the back of the cylinder you would construct geo to extrude cut the other angle on the ramp then do a boolean remove I can post an example tomorrow....not at my Mastercam computer tonight do you have a file or a better picture ...possibly some dimensions?
    A lot of times with the solids how I end up getting something to work is not the same as how I set out to do it
    Jan 2008
    123
    See if this is what you had in mind There might be another way to do it ,this is just my first try ....maybe it will give you and idea of where to begin
    Attached Files Attached Files
  1. need help with making a cad file
    By cloverfield333 in forum Solidworks
    Last Post: 08-20-2009, 05:08 PM
  2. converting a mastercam 9 file into a Solidworks file
    By Michael82 in forum Solidworks
    Last Post: 04-17-2009, 07:14 PM
  3. i need held in making a solidworks file.
    Last Post: 02-14-2009, 05:53 PM
  4. Need help in making a solidworks compatible file
    By brianklein in forum Solidworks
    Last Post: 05-27-2008, 02:32 AM
  5. making a subprogram in mastercam
    By tony88 in forum Mastercam
    Last Post: 03-15-2004, 04:49 AM
