Hello everyone. Been a long time since I have posted here but my new hobby has me using my harbor freight milling machine again.
I have the habor freight mini mill.
I need to cut and shape about 1/4 to 1/2" inch steel plates. I am shaping steel to work as a torque arm on a bicycle so the cuts/edges do not have to be smooth.
I was wondering what is the best end mill size and type to use to shape it? The edges do not have to be perfect so should I use a roughing end mill?
Since I do not need to make any cuts in the middle of the steel, just trimming away the edges, what size would work best?
The reason I ask size is I know that if the end mill is too small it will break easily when you move it around. But I would think that a larger end mill will cut more away when all you want to do is trim away edges.
Should I use a 2 flute or a 4 flute?
