588,551 active members*
5,469 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > when the cnc router is build, how do you make it work?
Hybrid View
    Jul 2007
    5
    Hey guys,
    must sound dumb to most of you guys but i'm new to this, i'm seriously thinking about building a cnc router, but once it's fully assembled do you only need to plug it in your computer?
    where can i get more info about operating from the start a cnc router?
    Thank you very much
    francois
    Jul 2006
    123
    heres a site that has some of the build in a generic way... http://buildyourcnc.com/default.aspx basicly, once you get your cnc router built, with controller boards and motors, you use one of the many programs to run your files, i use mach3 ( nice and easy, but $159)
    or you can use emc or turbo.
    best way ( at least for me,) is to wade in and start swinging.
    i have built 2 that way, and working on a third each progressivly bigger.
    so my sign making path goes...
    idea
    turbocad drawing
    dxf
    lazycam
    mach3
    and then sometimes all the way back to turbocad to redraw, till it's just right
    but once your done, that program is good.
    hope this helps
    dan
    May 2007
    cnc foam cutter
    I want to build an eps foam cutter .
    Is it any different from a router or a milling machine?
    May 2007
    I want to make a eps foam cutter .
    Is it any different from a router or milling machine?
  1. Newbie - To build or not to build Router/Plasma Table
    By dfranks in forum Waterjet General Topics
    Last Post: 04-08-2011, 05:16 AM
  2. Anybody here using Cimcool and can make it work?
    By phantomcow2 in forum MetalWork Discussion
    Last Post: 08-30-2006, 05:08 PM
  3. Time to make it work
    By DESERT RAT in forum DIY CNC Router Table Machines
    Last Post: 02-22-2005, 02:30 PM
  4. Trying to make this work- G code
    By WOODKNACK in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-10-2003, 06:00 PM
