Hi guys, i am from Brazil,
i want to buy a chinese 3kw spindle motor water cooled(24000rpm).
So i have some questions...
Can i milling aluminium easy?
i have a spindle with 600watts and 30000 rpm in my machine (homemade spindle-bosch)
i have some problems with finishiments, the aluminium fininsh is not shining...
I think 600 watts is to weak to machine aluminium , i can reard rpm dowing...
Now i can run feed rate 500mm/min and 1mm passes (end mill 6mm-4 theet) using 50% of end mill diameter...
and i would like to upgrade my milling machine and have a better finish
So, do you guys have some experiences on aluminium??
what you think about this chinese spindle??
what feed rate you guys use on alumnium with 3kw spindle...
Thanks so much and sorry about my english
