588,224 active members*
4,434 visitors online*
    Oct 2008
    9
    Eztrak X axis will not home
    I have a 2001 Eztrak that worked fine before I moved it to my garage, now the x axis will not home but just slowly moves till it alarms out (X DAC underflow). Ive swapped the X and Y servos, no change. What can I look for?? Also does anyone have a wireing schematic.
    Sid
    Nov 2007
    31
    Sid, I a no expert but I hav an z rack in my garage that has given me fits fro time to time.
    Mae sur the table is unlocked and that your micro swich is not suck and that all connections are sound.
    Steve
    Oct 2008
    9
    Thanks for the input Steve, I`ll check the switches today.
    Sid
    Nov 2004
    3028
    Are the drives turned ON when they drift?
    Usually a drift occurs when you lose the position loop and the balance of the drive is a bit off center. But a DAC underflow means that the control is seeing the encoders and they are moving when they are not supposed to.
    I would be checking the 12 VDC which presence turns the drives off.
    George
    Oct 2008
    9
    The X axis drifts when it tries to home but it will not home before it alarms out. I`ll check the VDC thanks.
    Sid
  1. Problem with my EZTRAK 3-axis
    By Ingchema in forum Bridgeport / Hardinge Mills
    Last Post: 09-21-2008, 07:47 PM
  2. Problem with my EZTRAK 3-axis
    By Ingchema in forum Trade Shows / Webinars / Other Events
    Last Post: 09-16-2008, 01:59 PM
  3. Ver 7.0 Eztrak 2 axis. Spindle wont turn
    By MrMudd in forum Bridgeport / Hardinge Mills
    Last Post: 06-13-2006, 07:18 PM
  4. EZTrak with factory installed 3rd axis.
    By Gncc50 in forum Bridgeport / Hardinge Mills
    Last Post: 04-08-2006, 07:13 PM
