So, after 2 years of having a kflop and konnect setting on the shelf I finally installed the thing this week. Got XYZ working but I am not sure what to do on the spindle. I am using a 3.5kw mitsubishi servo which is set up for step/dir inputs. Currently 750 pulses per rev at a max of 5000 rpm. I also plan on using the encoder output from the drive to feed back for rigid tap later on, I still have to run the encoder wiring. Servo is connected to channel 3.
so, how do I set this up?
