588,150 active members*
5,301 visitors online*
    Jul 2011
    28
    Laser head touch the left axis
    Hello
    I have a problem with a Chinese laser machine. When I press DATUM, the head moves toward the left point at the bottom but it affects the axis Y left, it will hit the left axis and of coarse vibrations with disturbing noise. This happens when it is in a position more close to me and quite near the left axis on the X axis. If I let it continue, the problem will disappear as soon as it goes beyond the middle of the axis Y. On the other hand, when the laser head is positioned initially say after half of the axis Y even if it is quite close to the X axis, it does not have this anomaly and continues its path normally.
    So, in your opinion, what is the cause of this problem?
    Thanks for your help.
    Chinese Laser : Jinan XYZ-TECH CNC Equipment Co,.LTD, Machine : XJ6090, RECI 100 W, MPC6515, Control Panel PAD03, HW 4.0.0.1, FW 4.1.2.3, DLL 4.1.2.2. LaserCut 5.3.
    Mar 2017
    5
    Have you ruida controller?
  1. NEWBIE NEED HELP HOW TO CONFIG 5 AXIS HEAD HEAD B/C MACH 3
    By plast744 in forum Mach Software (ArtSoft software)
    Last Post: 07-14-2014, 02:57 PM
  2. Spindle power dropping out as i toggle X axis left and right above 1,600 rpm Help!
    By kognition in forum Charter Oak Automation Support Forum
    Last Post: 06-14-2013, 03:39 PM
  3. Laser Head won't move along Y axis...
    By jassk in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-03-2012, 04:42 AM
  4. Chinese laser: when I press the left button, head goes right...
    By Mchawkeye in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-16-2012, 08:33 AM
  5. Z axis touch probe
    By Swede in forum FlashCut CNC
    Last Post: 08-29-2007, 06:09 PM
